Scan File Types by Registration Software Supported by As-Built
The following table lists the supported scan file types (point clouds) by As-Built™ for AutoCAD® Software, As-Built™ for Autodesk Revit® and VirtuSurv
Manufacturer | Software | Registered Scan File Types |
FARO | SCENE | FLS, FWS, LSPROJ |
Leica | Cyclone | PTG, E57, PTZ, PTX, ZFS |
Topcon | Scan Master | CLR (+ALG), CL3 (+ALG & IJ) |
Trimble | Realworks | E57, PTX (slow) |
Riegl | RiScan | RSP, RXP (no VS) |
Z & F | LaserControl | ZFS, ZFPROJ |
Optech | Polyworks | E57, PTX, IXF |
Independent | N/A | ASCII (pointcloud) no VS E57 (binary not text) LAS (pointcloud) no VS |
Stonex | Reconstructor | E57, PTS |
LFM | Register | PTX per scan position |
