Setup Guidelines for Checkerboard Targets with the Laser Scanner
• Depending on the chosen scanning resolution, the detection of checkerboard references in the scans by SCENE may get unreliable beyond a certain distance to the scanner. E.g. when using A4 checkerboard references and scanning with a resolution of 1/4, the distance to the scanner should not be greater than 15m. Larger distances can easily be achieved by enlarging the size of the target or scanning with a higher resolution.
• Checkerboard targets should not be rotated by 45° in relation to the scanner's axis.
• Have sufficient scan points on the checkerboard targets. They need four or more scan points per quadrant.
• Checkerboard targets should not be attached to a curved surface
Keywords: Focus, checkerboard, target, reference
