USB Driver for the FaroArm, ScanArm, and Gage
Your FaroArm®, ScanArm, Design ScanArm, or Gage works best with the latest driver. This article shows you how to download the latest or earlier drivers.
After servicing or recalibration of your device, plan to download and install the latest driver BEFORE you use the device. The factory provides the most recent hardware improvements when servicing your device, so using the latest driver may be required.
CAUTION: If you use software or hardware from a third-party vendor who makes FARO compatible products, verify the product is compatible with the latest USB FaroArm driver BEFORE you change the driver.
- If you are using the vendor recommended driver, do not change it.
- If you are not using the recommended driver and the vendor's product is not compatible with the latest USB FaroArm driver, see the earlier drivers list in this article to find the driver the vendor recommends.
Details
- Download the latest FaroArm driver:
Version: 6.11.21
Release Date: 31 Jan 2025
Download
- Download the What's New file to learn what has changed in the latest version.
- Go to Upgrade the FaroArm USB driver installation instructions.
Earlier Drivers
Click here for details about which versions of Microsoft Windows supports different driver versions and computer processors.
Date | Version | Download |
Aug 2023 | 6.10.55 | Offline edition |
Feb 2022 | 6.9.14 | Offline edition |
Jul 2021 | 6.8.9 | Offline edition |
Jul 2021 | 6.7.63 | Offline edition |
Dec 2020 | 6.6.7 | Offline edition |
Aug 2020 | 6.6.0.15 | 64- & 32-bit Offline edition |
Jan 2020 | 6.5.1.4 | 64- & 32-bit Offline edition |
Aug 2019 | 6.4.1.2 | 64- & 32-bit Offline edition |
Feb 2019 | 6.3.1.5 | 64- & 32-bit Offline edition |
Nov 2018 | 6.3.0.11 | 64- & 32-bit Offline edition |
Oct 2018 | 6.2.1.9 | 64- & 32-bit Offline edition |
Aug 2018 | 6.2.0.26 | 64- & 32-bit Offline edition |
May 2018 | 6.1.2.7 | 64- & 32-bit Offline edition |
Mar 2018 | 6.1.1.6 | 64- & 32-bit Offline edition |
Feb 2018 | 6.1.0.21 | 64- & 32-bit Offline edition |
Nov 2017 | 6.0.2.3 | 64- & 32-bit Offline edition |
Oct 2017 | 6.0.1.9 | 64- & 32-bit Offline edition |
Aug 2017 | 6.0.0.63 | 64- & 32-bit Offline edition |
Nov 2016 | 5.8.5.2 | 64- & 32-bit Offline edition |
Mar 2016 | 5.8.4.5 | 64- & 32-bit Offline edition |
Feb 2015 | 5.8.3.2 | 64- & 32-bit |
Dec 2014 | 5.8.2.2 | 64- & 32-bit |
Sep 2014 | 5.8.1.3 | 64- & 32 bit |
For older drivers not listed above, contact Customer Support.
Hardware Support Notes:
The latest driver version is compatible with all USB FaroArm and ScanArm models*. Model specific, minimum required versions are listed below.
Model/Device | Minimum Required Driver |
6.7.63 |
6.3.0.11 |
6.2.0.26 |
6.0.0.63 |
5.8.5.2 |
5.8.4.5 |
* Provided the FaroArm firmware is up-to-date.
**8-Axis support for the Edge requires an authorized firmware upgrade, contact your local sales representative for details
See Also
- Find the FaroArm USB driver version installed on computer
- FaroArm Manager Introduction and General Instructions
- Firmware Download and Installation Instructions for the Quantum S and Quantum M
- Driver, firmware, and kiosk software download for FaroArm Edge
- Firmware download for Laser Line Probe (LLP)
- Windows operating systems compatibility with FARO software
- Upgrade the drivers on a Serial FaroArm
- Warranty Benefits and Management
Keywords
faro usb driver, faro arm driver, reinstalling, reinstall, re-install, updating, update, LLP driver, Laser Line Probe driver, OS, operating system, latest driver, current driver, newest driver, new driver, earlier driver, past driver, old driver, dsa
