All All - FARO Products
FaroArm FaroArm - All Models
LLP V1 V2 V3
USB FaroArm
All Models
Chinese
English
German
Japanese
Spanish
Verifying the accuracy of the USB FaroArm or Laser ScanArm
If you are experiencing accuracy or repeatability problems with your USB FaroArm or Laser ScanArm system, this guide will demonstrate proper setup techniques and help you identify the potential sources of error.  It is important to clearly understand all the “do’s and don’ts” in order to get the most out of every USB FaroArm and Laser ScanArm systems.  Please see the attached link, "FaroArm and ScanArm Performance Verification Checklist"
Please note plane-to-plane dimensions are only acceptable on certified artifacts. These artifacts are precision machines to have near perfect parallel surfaces.  When measuring the distance between two sides of a regular plate or block, plane to plane is NOT recommended.
FAROarm, Scanarm, verification, USB arm, laser line probe, LLP, scanner, platinum, titanium, accuracy checklist, arm setup
