As-Built
AutoCAD
As-Built for AutoCAD Feature Data Tutorial - Facade Damage Mapping
After this tutorial you will be able to:
Part 1 – Data Capture
  • Capture areal and linear damage including specific attributes
  • Create links between different types of damage
  • Visualize attributes
  • Insert a legend
Part 2 – Customize a Structure Definition
  • Change the name of the structure definition
  • Customize and add new attributes
  • Sort attributes
  • Add new visualization types
  • Re-use your structure definition
You will find drawing utilized in the following tutorial is pre-installed with the software and is accessible via the As-Built Feature Data tab under "Tutorials Mapping>Tutorial 1 & Tutorial 2" (as shown in the video).
Part 1 - Data Capture
Part 2 - Customize a Structure Definition
