As-Built
Revit
Technical Requirements for As-Built for Autodesk Revit
Ensure software compatibility before you install or upgrade As-Built™ for Autodesk Revit® Software.
Platform
Operating system 64-bit Windows® 10 (version 1903 or higher) or Windows 11
Recommended hardware requirements Graphics card as recommended by Autodesk, RAM at least 8 GB, better 32GB and more, processor at least 2.5 GHz, better 3-4 GHz and 4-8 cores, SSD for larger projects; Laser scanner type to suit job in hand.
Data requirements Registered scans (and images).
Supported scan data formats
