2026
2025
Supported Datum Types in CAM2
CAM2® supports planar and linear datum types. When applying datums to a feature, it is important to select the correct type, to avoid incorrect calculations. The table below details what features can be used as datums, and how / where datum type is located.
Download a PDF of this procedure:  GDT001: Supported Datum Types
Key
GDT001LineFeature.jpg Feature
GDT001LineDatum.jpg Datum type / location
Feature Planar Datum Linear Datum Comments
Plane GDT001PlanePlanar.jpg Not Supported
Point Not Supported Not Supported Multiple points can be used to construct a supported feature.
Vector Point GDT001VectorPlanar.jpg Not Supported
Sphere Not Supported Not Supported Multiple spheres can be used to construct a supported feature.
Torus GDT001TorusPlanar.jpg Not Supported
See Also
GD&T, Help Sheet, GDT001
