Installation Procedure for Measure Q Software
Before you install Measure Q, we highly recommend that you are connected to the internet so that the application may download any necessary updates such as DirectX.
Measure Q can be installed via an executable file or via a CD.
Via CD:
  1. Place the Measure Q DVD-ROM into the computer's DVD-ROM drive. The DVD-ROM should automatically load and open the Measure Q Window. If the DVD-ROM does not automatically open the Measure Q window, go to My Computer, double click your computer's DVD drive and double-click autorun.exe.
  2. Choose an installer language.
  3. Click the 32-bit, 64-bit install button. Or, click the VIEW MANUAL button to move to the Measure Q manual menu. Adobe Acrobat Reader is required to view the manual.
  4. If necessary, the Measure Q install program displays a list of auxiliary system programs that are required for Measure Q. Click INSTALL to continue. Click OK to confirm the install of each program. A system restart may also be required during this section of the install.
  5. Read the Welcome screen and click NEXT.
  6. Read and accept the Software License agreement. Click the proper radio button, and click the NEXT button to continue.
  7. Add or remove a component by clicking on the individual component.
  8. Click the CHANGE button to change the destination folder for Measure Q, or click the NEXT button to create the default folder.
  9. Click the INSTALL button to begin installing the software.
  10. Click the FINISH button when the installation is complete.
See the link below for screenshots.
Click here to download: Measure Q Install Screenshots
Via *.exe file:
  1. Download the file. Double-click the EXE file.
Upon opening up Measure Q, you will either need a portlock (dongle) inserted into the computer or a license key code for the software to open properly.
Keywords: installation, install, Measure Q
