CAM2 CAM2 - 2021
Measure Q
Move Device Position with Comp off Points Using Measure 10 or Q
Move Device, or leap frog, is a command used in Measure Q or Measure 10 to realign previously measured data back to a measurement device after a part or device has moved. Please see the attached method sheet on how to perform a Move Device Position with Comp Off Points. This document was written using Measure Q, but the same process is used in 10.
Click here to download: Move Device Method Sheet Measure
Keywords: move device position, Measure q, comp off points, Measure m10
