Move Device Position with Point Reducible Features Procedure Using Measure 10 or Q
Move Device, or leap frog, is a command used in Measure Q or Measure 10 to realign previously measured data back to a measurement device after a part or device has moved.
Please see the attached method sheet on how to perform a Move Device Position with point reducible features. The method sheet describes the steps in Measure Q, but the same basic procedure is used in Measure 10.
Click here to download: Move Device using Different Kinds of Point Features
Move device, point reducible
