All All - FARO Products
FaroArm FaroArm - All Models
ScanArm or Laser Line Probe ScanArm or Laser Line Probe - All Models ScanArm or Laser Line Probe - FAROBlu HD/SD V6 ScanArm or Laser Line Probe - ES V5 ScanArm or Laser Line Probe - Edge LLP V4 ScanArm or Laser Line Probe - LLP V1 V2 V3 ScanArm - Design ScanArm 2.0
Laser Tracker Accessories Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION Tracker Accessories - Si X Xi
Laser Scanner 3D Laser Scanner - Focus S 3D Laser Scanner - Focus M 3D Laser Scanner - Focus E 3D Laser Scanner - Focus3D 3D Laser Scanner - Focus3D X 3D Laser Scanner - Focus3D X HDR 3D Laser Scanner - Focus3D S 3D Laser Scanner - Photon
Laser Projector Laser Projector - Tracer Scan Head - Digi-Cube
Measure
English
Reverse Engineering Procedures with a Manual CMM and Measure
Setting Alignments:
  • Measure a plane on the top surface of the part, this will be your XY plane. From the Measure menu, select Plane.
  • From the Measure menu, select Line < 2D Line . Measure the edge that will define your X-axis.
  • From the Measure menu, select Line < 2D Line . Measure the two outside edges that will define your centerline.
  • From the Construct menu, select Line < Bisector . Use M_LINE2 and M_LINE3 to create the centerline.
  • Set the origin. From the Alignment menu, select 3-2-1 Alignment < Line/Line . Use M_PLANE1 as the XY Plane, M_LINE1 as the X-axis, and C_LINE1 as the second line.
  • Set the coordinate system to World/Absolute. From the Alignment menu, select CAD to PART < CAD=PART.
Measurements:
  • Measure any flat surfaces as planes. From the Measure menu, select Plane.
  • Measure the two holes on the top of the part as circles. From the Measure menu, select Circle.
  • Project them to M_PLANE1.
  • Perform the scans to generate the part profile. From the Measure menu, select Scan Options < Freehand Scan.
  • Perform a 3D scan.
  • Set the minimum distance to 0.25 inches.
  • Save data as an Open Polyline.
  • Lock the Machine at the correct Z height.
  • Press the left button (on the footpad) to begin scanning and the right button twice when done.
  • Repeat for other Z heights.
Data Output:
  • From the File menu, select Export < IGES. Save the file so that it can be used in another CAD system.
Click here to download: Reverse Engineering
Keywords: reverse, engineer, engineering, cmm
