Language Quality HT MT AT NT
All All - FARO Products
FaroArm FaroArm - All Models
USB FaroArm USB FaroArm - All Models USB FaroArm - Quantum S USB FaroArm - Advantage USB FaroArm - Digital Template USB FaroArm - Edge USB FaroArm - Fusion USB FaroArm - Platinum USB FaroArm - Prime USB FaroArm - Quantum USB FaroArm - Titanium
Public Safety Public Safety - All Software Public Safety - FARO CAD Zone Fire Insurance Public Safety - FARO CAD Zone Crime Crash Public Safety - FARO CAD Zone CZ Point Cloud Public Safety - FARO CAD Zone First Look Pro Public Safety - FARO Zone 2D Public Safety - FARO Zone 3D Public Safety - FARO 360 Reality Public Safety - FARO 360 HD Public Safety - FARO 360 Blitz Public Safety - FARO 360 Genius
PointSense1 PointSense - All PointSense Suite PointSense - PointSense Basic PointSense - PointSense Pro PointSense - PointSense Building PointSense - PointSense Plant PointSense - PointSense Heritage PointSense - PointSense for Revit PointSense - TachyCAD Building PointSense - TachyCAD Archeology PointSense - TachyCAD Interior
PointSense2 PointSense - PhoToPlan Basic PointSense - PhoToPlan PointSense - PhoToPlan Pro PointSense - PhoToPlan Ultimate BIM CIM - DisToPlan BIM CIM - MonuMap BIM CIM - hylasFM BIM CIM - VirtuSurv
Factory Metrology Factory Metrology - All Software Factory Metrology - Visual Inspect App Factory Metrology - Visual Inspect CAD Translator Factory Metrology - RayTracer
Measure
English
Scanning a Profile to Compare to Nominal CAD Data in CAM2 Measure X, 4 or 3
Application Description
Scan a cross section of a symmetrical part to compare it to a CAD Nominal.
Setup
  • Mount the part securely by clamping or bolting the part.
  • Open a new file in CAM2 Measure. Go to FILE> INSERT CAD PARTS to import the nominal CAD data.
Constructions
  • From the construct menu, choose CONSTRUCT> CIRCLE> NOMINAL. Select 3 points on the bottom circle to establish a nominal circle.
  • From the Construct Menu, choose CONSTRUCT> POINT> NOMINAL. Select any point along the bottom circle. This will be used to establish the direction of the X-axis.
  • From the construct menu, choose CONSTRUCT> COORDINATE SYSTEM> 321. Choose N_CIRCLE001 for the +XY plane, First point on axis is N_CIRCLE001, Second point on axis is N_POINT001, direction of axis is +X, and origin is N_CIRCLE001. Choose the Nominal radial button and select okay.
Alignment
  • Choose MEASURE> PLANE. Measure the bottom plane of the part.
  • Choose MEASURE> CIRCLE. Measure the bottom circle of the part. Use M_PLANE001 as the plane.
  • Choose MEASURE> POINT> COMP OFF. Measure a point on the outer surface, along M_CIRCLE001.
  • From the construct menu, choose CONSTRUCT> COORDINATE SYSTEM> 321. Choose M_PLANE001 for the +XY plane, First point on axis is M_CIRCLE001, Second point on axis is M_POINT001, direction of axis is +X, and origin is M_CIRCLE001. Choose the Constructed radial button and select okay.
  • Choose ALIGNMENT> CAD=PART. Measured Coordinate system will be C_COORDSYS001 and Nominal coordinate system will be N_COORDSYS001. Select OK.
Measurements
  • From FILE> PREFERENCES> MISCELLANEOUS (Part Preferences) set Save Scan Lines as Features to Yes.
  • From FILE> PREFERENCES> SCAN MEASUREMENT (Part Preferences) select Start/Pause Scan with trigger, and set minimum distance to 2mm.
  • Choose MEASURE> SCAN> RADIAL LOCK PLANES. Select M_CIRCLE001 as the line. Set number of planes and minimum distance as desired. Begin scanning.
  • When scanning is complete, pull away from the surface to compensate.
Reporting
  • By turning on whiskers (Highlight feature in review features and mark the Whiskers box) you may see visual error bars representing where the scan is in/out of tolerance.
  • From review features, select print. Enter header information, and select items to include on your report. This report will provide the maximum, minimum, average and standard deviation of the distance from the scanned points to the nominal surface.
Please see the attached document for more details.
Click here to download: Scanning a Profile to Compare to Nominal CAD Data
Keywords: scanning, nominal, CAD
