All All - FARO Products
FaroArm FaroArm - All Models
English
Setting up a Network License for CAM2 Q
Please see the steps below on how to install the network license for CAM2 Q. Please note that the RED networked portlock purchased from FARO is required for these procedures to work.
Installation of Network Licenses
The installation of the Network license will require additional steps to make it work. The user will need:
  1. The client computer that will run CAM2 Q
  2. The server computer that will run the license server
  3. CAM2 Q installation DVD
  4. A network port lock configured with one or more CAM2 Q licenses
Note: these instructions are only necessary if the connecting to a port lock that will not be running CAM2 Q. the port lock will operate like a non-network port lock if plugged into the same computer that is running CAM2 Q.
Server setup
The server is the computer where the port lock will be plugged in. It must be on a network in order for the client machines to be able to access it and be allowed to run CAM2 Q.
  1. Install the haspdinst.exe program that comes with the CAM2 Q installation DVD.
  2. Remove any portlocks on the system
  3. From the DVD run the menu item “HASP Server License Manager”
  4. Plug the port lock into the server computer.
  5. Open a web browser and access the following web page: http://localhost:1947/_int_/config_to.html. You will see across the top a tab named Access to Remote License Managers. Make sure that the Allow Access to Remote Licenses’ option is turned on.
User-added image
Client setup
The client is the computer that will be running CAM2 Q. It must be on a network that can access the server to be allowed to run CAM2 Q.
  1. Install CAM2 Q using the CAM2 Q installation DVD.
  2. Open a web browser and access the following web page: http://localhost:1947/_int_/config_to.html. You will see across the top a tab named Access to Remote License Managers. Make sure that the Allow Access to Remote Licenses’ option is turned on.
  3. Also check Aggressive Search for Remote Licenses and key in the server IP address in the Specify Search for Remote Licenses field.
  4. Launch CAM2 Q
User-added image
networked license, cam2 q, network
