CAM2 CAM2 - 2021
Measure Q
Three Feature Alignment Procedure Using Measure 10 or Q
The Three Feature alignment uses 3 and only 3 features to give a more exact alignment without best-fitting. More details can be found in the attached method sheet. This method sheet was written using Measure Q, but the same process is used with Measure 10.
Click here to download: Three Feature Alignment Method Sheet
Keywords: three feature, 3 feature, alignment, Measure Q
