User Manual for SCENE Capture and Process
Quick Steps
SCENE Capture, SCENE Process, and the FARO Freestyle3D Scanner work as an integrated system. So the User Manual for the FARO Freestyle3D contains information about Capture and Process.
- Click here to download the Freestyle3D User Manual.
Capture and Process provide all the features you need to record, process, and finalize your entire Freestyle scan project. Record your scans on a tablet computer using Capture, then transfer the data to a laptop or workstation and continue working with Process to finalize your project. Because processing 3D data is operationally demanding, Process is typically not used on the tablet computer that comes with your Freestyle.
Note: SCENE Process 2019.1 is the last supported version of SCENE Process software and should only be used with SCENE Capture 2019.1. SCENE Process functionality is available in SCENE 2019.1 and later versions.
See Also
user guide, handbook, getting started with SCENE Capture, Getting Started with SCENE Capture
