File Format to Import a Series of Control Points into SCENE
FARO® SCENE can import a series of points to create a coordinate system in a text or ASCII format.
The reference coordinate is set to the center of the sphere or paper target.
The file format must be: Point ID, X, Y, Z Accuracy
There must be a space in between each column. If there is no accuracy data available for the project, then a 0 should be used.
This is the only format that will be accepted by FARO SCENE.
Keywords: ASCII Import, text import
