Importing Scans from the Focus3D SD Card to SCENE
There are 2 options to transfer scans from an SD card to a computer.
- To transfer those scans, start SCENE first, then insert the Focus3D SD card into your computer. This SD card will automatically be recognized by SCENE and you will be asked whether to import the scans or not. Clicking yes will start the import process of the scans. SCENE will create a project folder within your regular import folder that is specified under Tools > Options > Directories > Import Folder and transfers the scans to it.
- Manually drag and drop the appropriate folder from the SD card to SCENE or use the Import command, which can be found in the menu bar under File. Open the folder of the appropriate scan, in this folder select the scan's identification file. This identification file bears the name of the scan and has the extension .fls.
scene, sd card, import
