All All - FARO Products
FaroArm FaroArm - All Models
ScanArm or Laser Line Probe ScanArm or Laser Line Probe - All Models ScanArm or Laser Line Probe - FAROBlu HD/SD V6 ScanArm or Laser Line Probe - ES V5 ScanArm or Laser Line Probe - Edge LLP V4 ScanArm or Laser Line Probe - LLP V1 V2 V3 ScanArm - Design ScanArm 2.0
Laser Tracker Accessories Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION Tracker Accessories - Si X Xi
Laser Scanner 3D Laser Scanner - Focus S 3D Laser Scanner - Focus M 3D Laser Scanner - Focus E 3D Laser Scanner - Focus3D 3D Laser Scanner - Focus3D X 3D Laser Scanner - Focus3D X HDR 3D Laser Scanner - Focus3D S 3D Laser Scanner - Photon
Laser Projector Laser Projector - Tracer Scan Head - Digi-Cube
All SCENE Suite
Chinese
English
French
German
Italian
Japanese
Random Changing of License ID Using Windows 7 with SCENE
You will have to obtain the MAC address of the laptop and send that to FARO Support as your system ID (instead of the one FARO Scene reports). The MAC address can be found by going to the MS DOS prompt (Start > RUN > key in "cmd") and keying in "ipconfig /all". A list of your ethernet connections will appear. Look up your main ethernet connection (most likely LOCAL AREA CONNECTION), then underneath it, record the physical address (also known as the MAC ID). See below for an example.
User-added image
NOTE: Ensure the MAC ID address does not have any dashes when sending it to Support.
Once that MAC ID is sent to a customer service specialist and inputted into FARO Scene's license generator, the license should work correctly.
windows 7, faro scene, license
