CAM2 CAM2 - 2021
2022
7.x
Processing and Registering Scans with SCENE
Processing and registering scans in SCENE is an intuitive process that begins after you have imported your scan data.
Process Scans
  1. Open the project.
  2. Click Project on the SCENE ribbon.
  3. Click Process Scans under Processing.
  4. Select the scans to process and click Configure Processing.
  5. Adjust the processing settings as desired.
  6. Click Start Processing.
If you get a screen that says processing failed it is likely that the SCENE couldn’t register the scans on its own. This could be for a couple of different reasons:
  • There may not be enough overlap between the scans.
  • The surfaces in the scene may be difficult to register, like blowing trees and tall grass.
  • Rooms or surfaces in one area of the scene may look similar to other areas in the scene which can throw off registration. Mirrors in the scene could duplicate a room.
Register Scans
Even if the scans registered successfully during the project transfer, you will need to view and verify the registration.
  1. On the project page, click Registration to check.\
  2. Click Verify Registration or the Scan Report icon.
  3. On the Register and Verify page, use the view toolbar at the bottom to compare your scans from different angles.
  4. If the scans are registered correctly, click Yes and Finish.
  5. If not, click No and Finish. You will be directed to register the scans again.
You can register scans later, by clicking the Registration tab on the SCENE ribbon.
Legacy Tutorials
SCENE 6 with SCENE 2go.
  Download the tutorial PDF.
SCENE 6 with Webshare 2go 2.0
  Download the legacy tutorial PDF
