CAM2 CAM2 - 2021
WebShare Cloud and WebShare 2Go App Feature Comparison
SCENE WebShare Cloud Icon
Question WebShare Cloud WebShare 2Go App
Preparing the SCENE project
Do I have to download additional software?
No
Use the SCENE WebShare Cloud Export option to prepare your scan project for WebShare Cloud
Yes
Download the WebShare 2Go App and use it to transfer the prepared scan project to a USB stick or a folder on your computer
Environment
Do I have to have an internet connection? Yes No
NOTE: Without an internet connection, the world map in the project selector does not  display correctly
Is Internet Explorer supported? Yes No
Annotations
Are annotations exported from SCENE displayed? Yes Yes
Is it possible to create new annotations in the browser? Yes
No
You create the annotations in SCENE and export them
Measurements
Are measurements exported from SCENE displayed? Yes Yes
Is it possible to create temporary measurements? Yes Yes
Is it possible to create permanent measurements in the browser? Yes
No
You create the measurements in SCENE and export them
3D View
Is it possible to view several scans in 3D View? Yes
No.
Only one scan can be viewed in 3D view
How long does it take for the 3D View to load?
NOTE: Loading time is mostly influenced by the selected 3D View detail level and your computer's CPU performance
Shorter upfront loading time Longer upfront loading time
Settings
  • Hyperlinks to local files can be added in SCENE. If you copy these files to the web\ws2go-data\documents folder on the WebShare 2Go App USB stick, you can open them by clicking on the Annotation's property page.
  • In the WebShare 2Go App, you can use the 3D View to select the points of the measurement. These measurements only appear in the 3D view.
  • All settings are saved in the browser's internal storage. If you do not use the Chromium browser on the USB stick (for instance on a MacOS system instead), your settings are stored locally on your computer and are not applied when using the USB stick on another computer.
  • For the Scan View setting 3D View Detail Level, only Medium, High, and Very High (HD) are available. Increasing the detail level increases the load-time of each 3D View. While you move the camera, the number of rendered scan points is reduced to achieve a higher frame rate.
See Also
comparison, features, characteristic, change
