Measure Q
Iterative Alignment with Surface Points Procedure Using Measure 10 or Q
In Measure Q and 10, it is possible to align to a CAD model using only Surface Points. For more details, see the link below. This method sheet was written using Measure Q, but the same process can be used in 10.
Click here to download: Iterative Alignment Method Sheet Measure
Keywords: surface points, iterative alignment, Measure q, Measure m10
