Measure 3/4
Creating an Operator Prompt to Input a Serial Number When Using SoftCheck Tools in Measure 4
You must change the preferences in Soft Check Tool Manager. You may do this by following this process:
Administrator > Tool Management > Select your tool > Tool Options > Select Yes under Serial Number, Part Name, etc.
This will prompt you to enter a serial number before measuring a part.
Keywords: serial, number, sct, softcheck, soft check
