Measure X
Measure 3/4
True Position, Profiling, Angularity and Straightness Tolerances for Measure X, 4 or 3
To measure position tolerances, surface profiling tolerances, angularity, and form of line tolerances according to ISO, in Measure X, 4 or 3, do the following.
1. Position - turn the RFS and MMC tolerances on. Use the datum features in the feature control frame for the alignment.
2. Surface Profiling - Inspect Surface command.
3. Angularity - none, unless the angle is 90 (Perpendicularity) or 0 (Parallelism). The only other solution would be to dimension the angle then calculate the angularity by hand.
4. Form of a line - Straightness (GD&T menu).
Keywords: true position, surface, angularity, profile, profiling
