Photonics WinLase - Pro WinLase - LAN WinLase - 6 Controller - LMC Series
Nutfield
Nutfield Software
How To Create a Grid Pattern in WaveRunner
A short guide in how to create a grid pattern in WaveRunner.
Procedures
  • Divide the full field five line segments in each direction. It is also in your best interest to mark each side with their axis and polarity.
  •  The mark should invert X. If your mark does not look like the image below, make sure you have not inverted any axis.
Note: (Set_Mode in SPC controls this function. Make a new mark until it is in this orientation.)
  • Make measurements at each line intersection.
    • Note that the +/- values are the real polarity of your axis.
    • If the bottom right corner point is X+60.004 and Y+60.123 on your measurement device you need to record them as X-60.004 and Y-60.123.
    • The center point is always 0,0. Your alignment to your measurement system needs to be centered on 0,0.
  •  Follow the numbered steps in the image below:
  1. Open the correction file you used to create the grid.
  2. Enter in 9 points or all 25
  3. Enter the measured value for X
  4. Enter the measured value for Y
  5. If you only entered nine points, click Mirror Corrections
  6. To mirror those entered points to the other four quadrants. Click Correct X_Y to create the new correction matrix.
 grid_pattern4.PNG|
  1. Select Save As
  2. Rename the file
  3. Save
  • Remark your image using your new correction file and measure.
  • Was this article helpful?
