Photonics WinLase - Pro WinLase - LAN WinLase - 6 Controller - LMC Series
1Click
Installing 1Click Software
1Click software is the operating application for Click scanners.
Versions
There are two versions of 1Click that can be installed:
1Click Full Setup
The full setup is a complete installer. This file .exe should be used for the first installation of the current version on a PC. It is used for a fresh install and to upgrade to a new software version number.
1Click Only Update Setup
This version is used for bug fixes and other minor updates. It cannot be used if there is not already a complete version of the same software installed on the PC.
In both cases, installation involves using the installation wizard.
Installing the Software
  1. Double-click on the downloaded software to launch the installation wizard. Windows might ask you if you want to proceed with the installations, if so, click Yes.
  2. Select the language, and click Next.
  3. Select full installation to install the necessary drivers, and click Next.
  4. Select Create a Desktop Shortcut, and click Next.
  5. Review your set-up and click Install. The files will be extracted and installed.
  6. Continue following installation prompts. At the end of installation, you will be prompted to restart your PC to complete installation.
