Photonics WinLase - Pro WinLase - LAN WinLase - 6 Controller - LMC Series
ScanWay
Installing ScanWay Software
ScanWay software is the operating application for NeWay scanners.
Versions
There are two versions of ScanWay that can be installed:
ScanWay Full Setup
The full setup is a complete installer. This file .exe should be used for the first installation of the current version on a PC. It is used for a fresh install and to upgrade to a new software version number.
ScanWay Only Update Setup
This version is used for bug fixes and other minor updates. It cannot be used if there is not already a complete version of the same software installed on the PC.
In both cases, installation involves using the installation wizard.
Installing the Software
  1. Double-click on the downloaded software to launch the installation wizard. Windows might ask you if you want to proceed with the installations, if so, click Yes.
  2. Select the language, and click Next.
  3. Select full installation to install all the necessary drivers, and click Next.
  4. Select Create a Desktop Shortcut, and click Next.
  5. Review your set-up and click Install. The files will be extracted and installed.
  6. Continue following installation prompts. At the end of installation, you will be prompted to restart your PC to complete installation.
