CAM2 CAM2 - 2021
PointSense
Plant
Tutorial Pipes PointSense Plant
In this 4-minute video, you will learn how to use scan navigation, create pipe runs efficiently (Walk The Run), apply constraints, export results, and create an ISO drawing.
Tutorial Data
To complete the following tutorial you will need to download the accompanying tutorial data. Click the link below to begin the download.
Note: If you have already downloaded the tutorial data found in PointSense Plant Prepare a DrawingPointSense Plant Tutorial Tie in Points, PointSense Plant Tutorial Steel, or PointSense Plant Tutorial Tank Analysis, you will not need to download the following tutorial data again as the same data set will aid you in completing this tutorial.
Tutorial Data Download
 Download
Video
  • Was this article helpful?
