License Transfer for FARO Software
You can transfer a FARO license key from one computer to another. This is typically done when replacing an old computer with a new one. If both computers are running on the same local network this transfer can be done using the Transfer Key function. If one or both computers are offline, or not on the same network, then the RUS Utility must be used. Depending on your situation, proceed to the appropriate section:
Note: If the old (source) computer is no longer accessible (such as a hard drive or other hardware failure) it is not possible to transfer the license key, please contact FARO Support.
Transfer Key – Network
The Transfer Key function provides the ability to transfer a license key that is located on another computer (on your network) to the computer you are currently using.
Prerequisites:
- Before proceeding be sure both computers have the FARO software installed and the old (source) computer has a valid and active software license.
- On the old (currently licensed) computer, be sure Access from Remote Clients is enabled in the Sentinel Admin Control Center.
On the new (target) computer, attempt to open the software.
License Wizard
- Click on Advanced Options, and the on the next screen, click on Transfer Key.
- The Transfer Key window appears:
- In the Available license on host dropdown box, select the computer that contains the license key you wish to transfer.
- Click on the desired key to highlight it
- Read and click the check box:
I fully understand that by clicking Next after selecting a license available on a specific host I will make it unavailable in that computer and available in this one.
- Click the Next button.
- The license manager will apply the license key you specified to the computer you are currently using.
License Manager
- Open the License Manager. The location of the License Manager varies with each software package but is typically found under the Settings or Help menu.
- Click on Transfer Key.
- The Key Transfer window appears. The License Manager will search your network for applicable license keys.
- If the License Manager was unable to find a license key, proceed to the “Transfer Key – No Network (RUS Utility)” section below.
- Click on the desired key to highlight it, then click the Transfer button.
Transfer Key – RUS Utility (No Network)
The RUS Utility allows the transfer of a software license between two computers that are either offline or not on the same network. Before proceeding be sure both computers have the FARO software installed and the old (source) computer has a valid and active software license.
On the new (target) computer:
Extract and run the RUS Utility. Click on the Transfer License tab.
- In the Step 1 section, click on the three dots “…” and specify a location and filename.
- Click the Collect and Save Information button.
Copy both this generated “.id” file and the RUS Utility to a USB thumb drive and move to the old (currently licensed computer).
On the old (currently licensed computer)
- In the Step 2 section, select the license to transfer.
- For the “Read the recipient information file from” field, click on the three dots “…” and select the .id file you generated from the new (target) computer.
- For the “Generate the license transfer file to” field, click on the three dots “…” and specify a location and filename for the .h2h transfer file.
- Click the Generate License Transfer File button.
Copy the “.h2h” file to your thumb drive and move back to the new (target) computer.
Open the RUS utility and click on the Apply License tab.
- For the “Update File” field, click on the three dots “…” and select the .h2h file you generated from the old (source) computer.
- Then click the Apply Update button.
The RUS utility will read the .h2h file and transfer the license to the current computer. Open your software and confirm the transfer was successful.
