Performance Specifications for the Focus3D
In this article you can find information on Performance Specifications for the FARO Focus 3D 20 and FARO Focus 3D 120.
Details
| Ranging Unit | |||||||||||||||||
| Unambiguity interval: | 153.49m (503.58ft) | ||||||||||||||||
| Range Focus3D 120/1: | 0.6m - 120m indoor or outdoor with low ambient light and normal incidence to a 90% reflective surface | ||||||||||||||||
| Range Focus3D 20: | 0.6m - 20m at normal incidence on >10% matte reflective surface | ||||||||||||||||
| Measurement speed: | 122,000 / 244,000 / 488,000 / 976,000 points/sec | ||||||||||||||||
| Ranging error2: | ±2mm at 10m and 25m, each at 90% and 10% reflectivity | ||||||||||||||||
| Color Unit | |
| Resolution: | Up to 70 megapixel color |
| Dynamic color feature: | Automatic adaption of brightness |
| Deflection Unit | |
| Vertical field of view (vertical/horizontal): | 305° / 360° |
| Step size (vertical/horizontal): | 0.009° (40,960 3D pixels on 360°) / 0.009° (40,960 3D pixels on 360°) |
| Max. vertical scan speed: | 5,820rpm or 97Hz |
| Laser (Optical transmitter) | |
| Laser power (cw Ø) | 20mW (Laser class 3R) |
| Wavelength | 905nm |
| Beam divergence | Typical 0.19mrad (0.011°) |
| Beam diameter at exit | 3.0mm, circular |
| Data handling and control | |
| Data storage: | SD, SDHC™, SDXC™; 32GB card included |
| Scanner control: | Via touch-screen display |
| New WiFi(WLAN) access | Remote control, Scan Visualization and download are possible on mobile devices with Flash® |
| Multi-Sensor | |
| Dual axis compensator: | Levels each scan with an accuracy of 0.015° and a range of ±5° |
| Height sensor: | Detects the height relative to a fixed point via an electronic barometer and adds it to the scan |
| Compass: | Electronic compass gives the scan an orientation. A calibration feature is included. |
