3D Laser Scanner
Focus Core
Focus Premium
Focus Premium Max
Swift
Focus3D X
Focus3D X HDR
Focus3D S
Traceable 3D Accessories
Traceable 3D is the high accuracy scanning solution we offer to our customers that includes hardware, software, accessories, and know-how. Traceable 3D Accessories are our suite of Target accessories and tools created by ATS that are used for high accuracy registration of point cloud scans.
Highlights included a unique washer that can easily and permanently mount for projects. Once installed and surveyed, these washers act as a benchmark for repeating scans within an established coordinate system. Target accessories, like a sphere or prism, can be magnetically mounted to this washer to add flexibility to a scanning project. All Traceable 3D accessories are designed for high accuracy repeatable scanning.
Traceable 3D accessories are now FARO-made, rather than vendor-supplied and will now be managed in inventory at FARO for fast turnaround. Contact us for more information or help finding the right solution!
Traceable 3D Accessories Guide
Features
  • Traceable high accuracy
  • Reusable data, incrementally updatable
  • Equal accuracy over time
  • Georeferenced to grid or map
  • Verifiable data whenever
  • Calibrated and traceable targets to assure quality
  • 1mm proved system accuracy on all targets; NOTE: The Durable M Sphere is 3mm.
  • Durable and discrete washer reference
  • Fast magnetic mounting of targets
  • Large range of targets for different purposes
  • Connectivity to multiple measurement systems
  • Comprehensive range of mounting accessories
Applications
Target registration (rather than cloud to cloud registration) can be used for any application. However, they are particularly useful and sometimes mandatory for environments that include:
  • Lack of a good diversity of fixed vertical and horizontal surfaces
  • Critical for narrow connections and other areas with poor scan overlap
  • Stairwells / Level changes
  • Survey control (geo-referencing)
    • Minimizes error propagation
    • Aligning scans to a known coordinate system
  • Industrial plants
    • Difficulty getting the right overlap between scans
    • A small gap due to a weak registration will make the modeling process more complex
Product Offerings
Image Part# Desc.   Image Part# Desc.
ACCSS0269.png ACCSS0269 T3D Tribrach Kit 1
  • 2 - T3D Premium L Spheres (Sphere Diameter: ˜198.8mm)
  • 3 - T3D Tribrach adapters
  • 1 - T3D Prism
  • Lightweight transport case (500 x 400 x 225 mm)
  ACCSS0272.png ACCSS0272 T3D Premium L Kit
  • 3 - T3D Premium L Spheres (Sphere Diameter: ˜198.8mm)
  • 1 - 50-pack T3D precision washers
  • Lightweight transport case (575 x 470 x 270 mm).
ACCSS0285.png ACCSS0285 T3D Premium M Kit
  • 5 - T3D Premium M Spheres (Sphere Diameter: ˜139mm)
  • 5 - Mini tripods with washer
  • 5 - Magnet extenders
  • 12 - Flat targets
  • 10 - Precision washers
  ACCS-TOOL-0033.png ACCS-TOOL-0033 T3D SMR Nest Adapter 6mm Kit
  • 3 - T3D SMR Nest Adapter 6mm
  • 3 - Reference Hole Adapter 6mm
  • 1 - Allen key, 3mm
  • Lightweight transport case (300 x 275 x 82 mm).
  • For nest shank Ø6mm
ACCSS6088.png ACCSS6088 T3D Starter Kit
  • 5 - T3D Durable Medium Spheres (Sphere Diameter: ˜139mm)
  • 5 - mini tripods with washer
  • 5 - magnet extenders
  • 5 - strap mounts with washer
  • 5 - locking pliers with washer
  • Absolute accuracy: Δx, Δy, Δz: ±3mm
  ACCSS6045.png ACCSS6045 T3D Tribrach Adaptor 5/8"
  • Fits all T3D Quick Releases
ACCS-MNT-0015.png ACCS-MNT-0015 T3D Quick release 1/2 kit
  • Contains only the parts for the mount on the tripod (3/8" or 5/8" UNC thread)
  • Enables the usage of multiple tripods
  • Fits to the upper part of all T3D Quick Releases
  ACCS-TRG-0012.png ACCS-TRG-0012 T3D Prism Kit
  • 3 - T3D Prism
  • Prism constant @ 660nm: For Trimble = -16.9 mm, for Leica= +17.5 mm.
  • Axis offset (x/y): 0.
  • Axis offset: (z): From ATS precision washer = 137 mm.
  • Absolute accuracy for centre point: Δx, Δy, Δz: ±1 mm.
ACCS-TOOL-0011.png ACCS-TOOL-0011 T3D Precision Washer, 50 pack
  • 50 pcs. Washers, bright zinc plated.
  • Diameter 36mm, thickness 3mm, countersunk center hole M4
  ACCSS8031.png ACCSS8031 T3D Quick Release
  • Focus M & S - Fits to standard photo tripods with 3/8" screw and surveyor tripods with 5/8" screws
ACCS-TOOL-0018.png    ACCS-TOOL-0018  T3D Prism Pole Adapter L12 w/precision washer   ACCS-TOOL-0030.png ACCS-TOOL-0030 T3D Precision Washer, 50-pack SS
  • 50 pcs. Washers, stainless steel EN 1.4057
