All All - FARO Products
FaroArm FaroArm - All Models
Laser Line Probe Laser Line Probe - Prizm Laser Line Probe - FAROBlu HD/SD V6 Laser Line Probe - Edge HD V6 Laser Line Probe - Edge ES V5 Laser Line Probe - Edge V4 Laser Line Probe - V3 Laser Line Probe - V2 Laser Line Probe - V1
Laser Tracker Accessories Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION Tracker Accessories - Si X Xi
Laser Projector Laser Projector - Tracer Scan Head - Digi-Cube
FaroArm Accessories
All FaroArm Models
Chinese
English
French
German
Japanese
Portuguese
Spanish
Calibration Procedure for a Foam Probe on the FaroArm
In order to use the foam probe, one must determine the effective probe radius.
  • Calibrate the ¼” or 6 mm ball probe as usual.
  • Measure a plane on a hard flat surface.
  • Measure a point in the cone of the Foam Probe with several hits.
  • Dimension the distance between the point and the plane.
  • Twice this value should be entered in the probe menu as the probe diameter when foam probe is in use, and when correct probe compensation is required.
Click here to download: Probe Calibration Procedure for Foam Probe
Keywords: custom probe, probes, probe, calibration, foam probe, disc probe
