Quantum X.S
Quantum X.M
Quantum X.E
Quantum S Max
Quantum M Max
Quantum E Max
Gage Max
Gage
Design ScanArm
Design ScanArm 2.0
Design ScanArm 2.5C
Forensic ScanArm
Dimensional Drawings for the 8-Axis Workholding Plates
The FARO® 8-Axis plate incorporates a threaded bolt hole pattern to support a wide range of workholding options and configurations. FARO offers two sizes of plates, the standard 250mm diameter version, p/n 448-000016-000 and a larger 500mm diameter version, p/n 443-000140-000 (contact your regional FARO account representative for ordering information). These plates attach directly to the top of the 8-Axis unit using the provided four M6 X 1.0 X 16mm flat-head socket cap screws.
Warning: The FARO 8-Axis maximum weight capacity is 220lbs (100kg). The user assumes all responsibility and risk for ensuring parts mounted to the 8-axis are secure, load balanced, and does not present a tipping hazard. FARO Technologies, Inc. disclaims any liability for injury, death or damages resulting from the use thereof.
Dimensional drawings of the workholding plates are provided below. These drawings are also available via download in a high-resolution PDF.
  • Material: Aluminum 6061-T6
  • Finish: .001 Thick Hardcoat Black Anodized, per (Mil-A-8625, Type III, Class II)
250mm Plate (std) - p/n 448-000016-000
500mm Plate (opt) - p/n 443-000140-000
Keywords
8axis, 8th axis, dims, dimensions
