Quantum X.S
Quantum X.M
Quantum X.E
Quantum S Max
Quantum M Max
Quantum E Max
Design ScanArm
Design ScanArm 2.0
Design ScanArm 2.5C
Forensic ScanArm
Laser Safety Specifications for FARO Laser Line Probes (LLPs)
Laser Safety
All FARO® Laser Line Probe models produce a visible laser beam. The laser is CDRH Class II and IEC Class 2 power level; however operation of the device requires the operator to avoid direct exposure to eyes at all times. You should avoid direct exposure to your eye at all times. Although the human blink reaction to bright light provides a natural mechanism of protection to this visible laser beam, use caution while handling the LLP by pointing it at only the target object.
LLP Technical Specification Table
Laser Line Probe Model Laser Color / Class (CDRH)* MPE** NHZ** NOHD** Power Output Wave Length Max. Scan Rate
FAROBlu®
xR, xP, xS
Blue / Class II 2.55mW/cm2
2.55mW/cm2
0.0m
0.0m
2.41m
1.64m
<1mW 450 nm
635 nm
(red crosshairs)
300frames/second
300fps x 4,000points/line = 1,200,000points/sec
Windowing enabled:
Max up to 600 frames/second
600fps X 2,000points/line = 1,200,000 points/sec
FAROBlu® xE Blue / Class II 2.55mW/cm2
2.55mW/cm2
0.0m
0.0m
2.41m
1.64m
<1mW 450 nm
635 nm
(red crosshairs)
200frames/second
200fps x 2,000points/line = 400,000points/sec
Windowing enabled:
200frames/second
Prizm™ Green / Class II not available <1mW 520 nm
635 nm
(red crosshairs)
Color:
120frames/second
120fps x 2,000points/line = 240,000points/sec
Monochrome:
300frames/second
300fps x 2,000points/line = 600,000points/sec
V6 FAROBlu® HD/SD Blue / Class II 2.55mW/cm2
2.55mW/cm2
0.0m
0.0m
2.41m
1.64m
<1mW 450 nm
635 nm
(red crosshairs)
HD:
300frames/second
SD:
120frames/second
120fps x 1,000points/line = 120,000points/sec
V6 (HD) Blue / Class II M 2.55mW/cm2
2.55mW/cm2
0.0m
0.0m
2.41m
1.64m
<1mW 450 nm
635 nm
(red crosshairs)
280 frames/second
280fps x 2,000 points/line = 560,000 points/sec
V4 (LLP) / V5 (ES) Red / Class II M not available <1mW 660 nm 60 frames/second
60fps x 752points/line = 45,120 points/sec
V3 Red / Class II M <1mW 660 nm 30 frames/second
30fps x 640 points/line = 19,200 points/sec
V2 / V1 Red / Class II M <1mW 660 nm 30 frames/second
*The Center for Devices and Radiological Health (CDRH).
**For more information on MPE, NHZ, and NOHD values, see: Laser Safety Calculation Guide
***xE (not available in US/Canada)
llp, safety, class, eyes
