Location of the Laser or Probe Calibration Window in Polyworks
This article explains how to locate the Laser or Probe Calibration Window in Polyworks.
Procedure
- You will have to ensure you have the latest Polyworks plug-ins.
- In the menu, select Plug-ins > FARO > Laser Line Probe.
- You can then:
- Click on "Select Probe" to calibrate the ball probe, or;
- Select scanner control to calibrate the LLP laser scanner.
calibration, 3rd party, SW, driver, plugin, laser line probe, hard probe, ball, digitize
