Settings for Scanning Reflective Surfaces With the V5 ES Laser Line Probe (LLP)
You can modify the algorithm settings to adjust for reflective surfaces. Follow the steps below and see the attached document for the steps with pictures.
- Select “Laser Probe” as the current probe.
- Click on “Edit” button.
- Click on “Laser Probe Settings” button.
- Click the “Advanced Settings” check box.
- Select “Automatic – Highly Reflective” algorithm.
- Click on “OK”.
- Click on “Modify” button.
- Click on “OK” in the Probe window.
You can also use Dynaflux to coat the part. See www.dynaflux.com. We suggest DNF315-16 DF-Developer Nuclear Inspection Grade - Crack Check.
scanning, laser line probe, shinny surface, powder coat, llp, llp settings
