Calibration with a Straight Probe Extension on a 3mm or 6mm Probe
Calibrating a 3mm or 6mm probe with a straight probe extension does not require modifying the probe. The probe will always be calibrated to probe center regardless of the size extension being used.
probe, extension, straight, calibrate
