SCENE SCENE - 2019
Advantage
Digital Template
Fusion
Legacy Quantum
Platinum
Prime
Titanium
Gage
Bluetooth
Plus
Power
Standard
Design ScanArm
Design ScanArm 2.0
Design ScanArm 2.5C
Forensic ScanArm
Serial FaroArm
Bronze
Gold
Silver
English
Specifications for the FARO UPS Battery Backup Power Supply - 225-90-005
The UPS FARO sells is made by APC and the specifications for model BR1500 (Part #: 225-90-005)can be found on www.apc.com
Back-UPS RS 1500VA 120VAC UPS (6) NEMA 5-15R (Backup) (2) NEMA 5-15R (Surge)
APC High performance battery backup and protection for business computers.
This high performance desktop battery backup features maximum protection in a versatile design. The fully featured APC Back-UPS RS can be placed on the floor, or on a shelf. Up to six battery backup outlets with automatic voltage regulation (AVR) enable you to work through even the most frequent brownouts and power sags, keeping 75/90/110 minutes of battery power for when you need it most. For printers and other devices that do not store or process information, up to three additional outlets provide surge protection. Both Ethernet 10/100BaseT and telephone dataline surge protection safeguards against surges entering via network connections. The PowerChute Personal Edition software features easy-to-use safe system shutdown with sophisticated power management.
Product Specifications:
Connectivity
Connector Power NEMA 5-15 (F)
Connector Power NEMA 5-15 (M)
Communication Interface USB
# Ports 8
General
Attributes RJ-11 line protection
Attributes RJ-45 line protection
Model Back-UPS RS
Form Factor 2U Rackmount
Form Factor Tower
Attributes Line interactive
Power
Power Provided 865 watt(s
Battery Average Run Time 3.7 minute(s)
Power Provided 1500 VA
Surge Suppression Standard
Actual Weight 25 lbs.
Compatibility Notes Communications and Management:
Interface port: USB
Control panel: LED bar-graph display of load and battery status with On Line, On Battery, Replace Battery and Overload Indicators
Audible alarm: alarm when on battery, distinctive low battery alarm, configurable delays
Surge protection and filtering:
Surge energy rating: 420 Joules
Filtering: full-time multi-pole noise filtering, 5% IEEE surge let-through, zero clamping response time, meets UL 1449
Dataline protection:
RJ-11 Modem / Fax/DSL protection (two wire single line)
RJ45 10 Base-T Ethernet protection
Contents UPS, CD with software, cord management straps, free trial of anti-virus : firewall : email privacy : system recovery and online backup software, USB cable, User Manual
Ports/Connectors (2) NEMA 5-15R outlets (Surge Protection)
(6) NEMA 5-15R outlets (Battery Backup)
(1) NEMA 5-15 input, 6ft cord
(1) USB management port
(1) RJ-45 input port (surge protection)
(1) RJ-45 output port (surge protection)
(1) RJ-11 input port (surge protection)
(1) RJ-11 output port (surge protection)
Power Notes Output:
Output power capacity: 865 Watts / 1500 VA
Maximum configurable power: 865 Watts / 1500 VA
Nominal output voltage: 120VAC
Input:
Nominal input voltage: 120VAC
Input frequency: 47 - 63 Hz
Input voltage range for main operations: 88 - 148VAC
Input voltage adjustable range for mains operation: 78 - 152VAC
Battery:
Maintenance-free sealed Lead-Acid battery with suspended electrolyte
Included battery modules: 1
Replacement battery cartridge: RBC33
RBC quantity: 1
Typical backup time at half load: 12.4 minutes (432.5 Watts)
Typical backup time at full load: 3.7 minutes (865 Watts)
Keywords: APC, ups
