3D Laser Scanner
Focus Core
Focus Premium
Focus Premium Max
Backpack Kit and Covers for the Focus Laser Scanner
In this article you can find detailed information on the Focus Laser Scanner Backpack Kit, Focus Standard Tripod Bag, Focus Dust Cover and the Focus Thermal Protection Covers.
Focus Laser Scanner Backpack Kit (ACCS-CASE-0011)
The backpack kit is compatible with Focus M, S, Core, Premium and i.1 scanner models and contains the backpack, tripod bag, and dust cover.
  • Size: Approximately 460 x 390 x 350 mm
  • Material: Black Nylon Fabric
    • Zipper on three sides
    • One front pocket with zipper, approx. 350 x 320 mm
    • On one side, pocket with zipper
    • On the other side, two strap loops for tripod
    • Focus foam insert
Tripod Bag (ACCS-CASE-0012)
  • Size: Approximately 760 x 110 mm
  • Material: Black Nylon Fabric with Zipper
Dust Cover (ACCS-CASE-0013)
  • Size: Approximately 255 x 100 x 215 mm
  • Material: Grey Nylon Fabric
Thermal Protection Covers (ACCSS8014 for battery side & ACCSS8049 for display side)
The thermal protection covers make it possible to operate the scanner in temperatures between 40 °C and 55 °C (104 °F to 131 °F) and in strong direct sunlight. The covers provide:
  • Shielding against IR radiation
  • High-performance thermal insulation to prevent excess heat intrusion
  • Latent-heat absorbers to remove excess heat from the device
For more information and installation instructions, see the Accessories Manual for the Focus Laser Scanner
