Changing the Wallpaper on the Focus3D Laser Scanner
To modify the wallpaper on the Focus 3D:
- Create a backup of your scanner settings (under Manage > Service > Backup)
- Remove the scanner's SD card from the Focus and connect it to your PC
- Open the folder of your backup on the SD card (Backup > Name of Backup)
- Look for a folder called "Wallpapers" If the folder is not available, create a new folder named "Wallpapers" in the directory of your backup folder.
- Copy the wallpaper pictures (jpg) to this folder. NOTE: The wallpaper pictures should have a resolution of 640 X 480 (height X width) pixels.
- Insert the SD card back to the Focus
- Go to Manage > Service > Restore and select your backup from the list.
- Restore the Focus.
