3D Laser Scanner
Focus3D X
Focus3D X HDR
Focus3D S
Improving Wireless Connection Performance for the Laser Scanner Focus3D X 330/130 or S 120/20
The FARO Laser Scanner Focus3D X 330/130 or S 120/20 use different wireless technology than older models. Therefore, the wireless connection performance might not be the same as that of older models. If your wireless performance is not what you expect, you may try using a Wireless LAN Repeater to extend the range of wireless performance. Check with your IT administrator to identify what is best for your computing environment.
connectivity, wi-fi, wifi, wlan, lan, network, connect, connection, blue tooth, bluetooth
