3D Laser Scanner
Focus Core
Focus Premium
Focus Premium Max
2D Hand Held Scanner
ScanPlan
Traveling with the FARO Focus Laser Scanner and ScanPlan
Guidelines and helpful tips when shipping, storing, and traveling with the FARO® Focus Laser Scanner and ScanPlan.
Transportation
  • The Laser Scanner must be turned off during transportation or shipping in a transport case.
  • Remove the battery before shipping.
  • When carrying it, take care not to drop it. Strong impact can damage the laser scanner and render it incapable of proper operation.
  • Carry the Laser Scanner separately from its equipment or, for best protection, use the original transport case.
  • When shipping and transporting by rail, sea or air, or in a road vehicle, make sure to use the original transport case and a suitable outer cardboard box for best protection against shock and vibration.
  • FARO batteries are lithium-ion batteries and thus, classified as dangerous goods. When transporting or shipping FARO batteries, ensure that observe all applicable local and international rules and regulations.
Traveling by Air
  • The Laser Scanner, along with all FARO equipment, should be carry-on items whenever possible.
  • If questioned as to what the item is by TSA agents, use proper wording:
    • The Laser Scanner is best described as a 3D imaging system.
    • The ScanPlan is a handheld floorplan/mapping tool.
  • Lithium-ion batteries must be carry-on items only. If a carry-on bag is checked at the gate or at planeside, all spare lithium batteries must be removed from the bag and kept with the passenger in the aircraft cabin.
    • For more information on how to travel by air with lithium batteries, please see this document, provided by the Federal Aviation Administration.
  • Focus and ScanPlan batteries are all under 100Wh, therefore, you may carry-on a maximum of 2.
    Note: Make sure that the total energy content of all batteries that you (as a single person) carry is less than 200 Wh.
              The maximum battery energy a single person can carry is 200 Wh.
  • For more on traveling with lithium batteries, reference the Federal Aviation Administration's PackSafe for Passengers page.
X-Ray Security Scans at Airports
Many of our customers travel with their scanners in their carry-on luggage. The intensity of radiation during a security scan is not critical for our electronics components. It is the same for our scanners as with laptops or phones/tablets which are also not impacted by security scans at airports.
Storage
Prior to storing the last scanner for longer periods of time:
  • Pack the scanner and the batter in its shipping case to protect it from environmental hazards, dust, and dirt.
Store all components in an environment where:
  • the humidity is low.
  • the temperature is relatively stable
  • they will not be subject to extreme temperatures, environmental conditions, or heavy vibrations.
