3D Hand Held Scanner
Freestyle3D Objects
Freestyle3D X
Freestyle3D
Calibration for Temperature Variations with the Freestyle3D
The Freestyle3D does not have built-in temperature sensors. If you use the Freestyle3D in an environment where the temperature varies, calibrate it before you use it. The carbon casing can expand or contract as the temperature changes, affecting the accuracy of your measurements.
This article and the FARO Freestyle3D Scanner User Manual have complete instructions about how to calibrate the Freestyle3D. In the manual, search using the keyword phrase User Calibration to find the instructions.
See Also
integrated temperature sensors, temperature gage, built in, builtin,
