3D Laser Scanner
Focus3D X
Focus3D X HDR
Focus3D S
Changing the Wallpaper on the Focus3D Laser Scanner
To modify the wallpaper on the Focus 3D:
  1. Create a backup of your scanner settings (under Manage > Service > Backup)
  2. Remove the scanner's SD card from the Focus and connect it to your PC
  3. Open the folder of your backup on the SD card (Backup > Name of Backup)
  4. Look for a folder called "Wallpapers"  If the folder is not available, create a new folder named "Wallpapers" in the directory of your backup folder.
  5. Copy the wallpaper pictures (jpg) to this folder.  NOTE:  The wallpaper pictures should have a resolution of 640 X 480 (height X width) pixels.
  6. Insert the SD card back to the Focus
  7. Go to Manage > Service > Restore and select your backup from the list.
  8. Restore the Focus.
