3D Laser Scanner
Focus3D X
Focus3D X HDR
Focus3D S
Creating 180 Degree Scans with the Focus3D Laser Scanner
This article guides you through the process of creating 180 Degree Scans with the Focus3D Laser Scanner.
Details
With the FARO Focus 3D Scanner, if a scan is manually configured to scan between 0 and 180 degrees or 180 degrees to 360 degrees, the scanner will still take a full 360 degree scan. If you would like to record a scan of a 180 degree field of view to reduce the scan size or to reduce the amount of time required for data analysis, the scanner should be configured to 1 to 181 degrees instead of 0 to 180 degrees.
This configuration behavior may be revised in a future version of the scanner firmware.
Last Updated: May 2012
Keywords: 180 degree scan, scanning problem
