All All - FARO Products
FaroArm FaroArm - All Models
Laser Scanner
All Models
All SCENE Suite
Chinese
English
French
German
Japanese
Portuguese
Spanish
Target Alignment Guidelines for Laser Scanners
For best possible automatic detection of references you should take care of the following:
Checkerboard references:
  • The angle of incidence between the laser beam and the checkerboard reference should not be smaller than 45°.
  • Depending on the chosen scanning resolution, the automatic detection of checkerboard references gets unreliable beyond a certain distance to the scanner. E.g. when using A4 checkerboard references and scanning with a resolution of 1/4, the distance to the scanner should not be greater than 15m.
  • The distance between the scanner and the references should not be smaller than 1m.
  • The checkerboard target should not be rotated by 45° in relation to the scanner’s axis.
  • The checkerboard reference should not be attached to a curved surface.
  • Print paper references with laser printers only.
Spheres:
  • The spheres should be completely visible in the scan. Make sure that they are not partly covered by other objects.
  • The radius of fit operations in the “Match Sphere Settings” (Tools -> Options -> Matching -> Match Sphere Settings, see 18.1.4.1.8.3) should be set according to the radius of the used spheres in the scan.
  • Depending on the chosen scanning resolution, the automatic detection of sphere references gets unreliable beyond a certain distance to the scanner. E.g. when scanning with a resolution of 1/4, the distance to the scanner should not be greater than 18m. The sphere should have at least 10-15 pixels in the scan.
Keywords: sphere, checkerboard, registration, references, objects, alignment, align
