Laser Tracker
ION
Si
X
Xi
Adjust Time Setting in the PSD Section of FARO Utilities Shows an Error Status with the Laser Tracker
The Adjust Time in the PSD Section on the Laser Page indicates how much time has elapsed since the PSD Auto Gain Adjust (during initialization or Startup Checks) was last completed. A time of 0:00:00 and a status of ERROR indicate that it was not successfully performed. When the tracker is turned off, this time and status is reset to 0:00:00 and ERROR. For trackers that have PSD Auto Gain Adjust disabled, the time and status will not be changed from ERROR because it was never performed.
PSD Auto Gain Adjust is used on older trackers and/or trackers with an interferometer.
Keywords: adjust time, psd
