3D Hand Held Scanner
Freestyle3D Objects
Freestyle3D X
Freestyle3D
FARO Freestyle3D Workflow Video Series
Freestyle3D Scanner
The following article outlines the operation and typical workflow of using the FARO® Freestyle3D. A series of seven videos is your guide from unpacking and setup, scanning and processing, and even combining Freestyle3D scans with Focus scan data.
Part 1 - Introduction
Discover the FARO® Freestyle3D for scanning objects and areas, beginning with the device and the case it comes in.
Cannot view the video? Click to here to download.
Part 2 - Using SCENE Capture
Part 2 will focus on SCENE Capture while using the Freestyle3D.
Cannot view the video? Click here to download.
Part 3 - Scanning 1
In part 3, you will see the step by step process of taking scans using the Freestyle3D.
Part 4 - Scanning 2
Part 4 continues the step by step process of taking scans using the Freestyle3D.
Part 5 - Using SCENE Process
Part 5 will show you how manually register images using tools provided within SCENE Process.
Part 6 - Registering Scans
Part 6 covers data registration. Follow along while learning about the different ways to capture scans into SCENE Process and more.
Part 7 - Combine Freestyle3D and Focus Scan Data in SCENE
In Part7, learn how to combine Focus3D and Freestyle3D scans in SCENE software.
