Fusion
Platinum
Legacy Quantum
Titanium
Advantage
Legacy Gage
Bluetooth
Plus
Standard
Power
Acceptance and Accuracy Verification for Platinum, Titanium, Advantage, Legacy-Quantum, Fusion, and Legacy Gage FaroArm
Attached are the steps to verify the accuracy of the USB series FaroArm.
06REF176-090- Acceptance / Accuracy Verification for USB FaroArms. (Advantage, Platinum & Titanium)
06REF176-142 - Acceptance / Accuracy Verification for FARO Gage Arms
06REF176-139 - FaroArm Setup & Techniques for Testing Accuracy
Note: Plane to plane dimensions are only acceptable on certified artifacts. These artifacts are precision machines to have near perfect parallel surfaces. When measuring the distance between two sides of a regular plate or block, plane to plane is NOT recommended.
Platinum, Titanium, Gage, Advantage, Accuracy verification, accuracy test, tests, test, accuracy, accuracy usb, usb accuracy, arm accuracy, gage accuracy, calibration, mounting, setup
