Default Pairing Code for Bluetooth Connection to the Edge FaroArm
FaroArm Edge Icon
The FARO Edge is Bluetooth equipped. When you pair the Edge with your computer using Bluetooth, you need to enter a PIN or paring code. The FARO Edge and Laser ScanArm Edge User Manual documents using the word faro as the PIN. If you have connection issues, instead of using faro, use 0000. Also, make sure the computer and the Edge are both within 30 feet or 10 meters of each other. This is the approximate maximum range for the Edge Bluetooth.
For a complete discussion of making the connection between the Edge and your computer, click here to download the manual and search for the Wireless Connections section.
