All All - FARO Products
FaroArm FaroArm - All Models
USB FaroArm
Advantage
Digital Template
Fusion
Legacy Quantum
Platinum
Prime
Titanium
English
Spanish
Button Replacement Procedure on the USB FaroArm
Below are the steps to replace the buttons on Legacy-USB FaroArm® models (not including the Edge)
  1. Unplug Arm.
  2. Make sure you are properly grounded before attempting to work on the arm. Static electricity can cause damage to the arm’s internal electronics
  3. Put masking tape over the Red & Blue Buttons (p/n 2759 & 2760) to avoid them  falling out when disassembling the handle.
  4. Remove 4 outside screws (XH03-0179) using a 1.5mm ball driver. Then remove the 2 inside screws (XH03-0176) on the side needing repair. Be careful not to loose the screws.
  5. Remove the Blue Covers (2761 7 2762). This will expose the Button Boards (CC78). There is one on each side.
  6. Unplug the connectors from the defective Button Board.
  7. Plug the connectors into the new Button Board. Note: Board is labeled front & back, front is for the green button and back is for the red button.
  8. Place Button Boards back in place being careful not to damage any of the wires.
  9. Place Blue Covers back in place and replace all the screws.
  10. Remove tape which was applied to hold the buttons.
  11. Test buttons to confirm that they are now functional.
User-added image
Keywords: replace buttons, replacing buttons, usb buttons
